Bike sat 6 mo, now very difficult to turn bars/forks....???
Since my crash last Dec and waiting on my broken ankle to finish healing I have not been riding so the R has been sitting. Yesterday I rolled it out to get the stator off to send to BD. The forks are really hard to turn. Do I have rusty bearings? Any other ideas?
Jim
Jim
river- XRR Jockey
XR650R Year: not yet
Re: Bike sat 6 mo, now very difficult to turn bars/forks....???
before you do anything else
put air in your tires
fiep- noob
XR650R Year: 2000 & 2005
Heh, thanks, but they are much harder to turn than flat tires would cause. Did check that but they have air.
Jim
Jim
river- XRR Jockey
Seems odd
Do you have a damper?
Is there any way water could have gotten into the triple tree stuff? Like stored outside or power washing or water crossings or ridden in rain before being put away?
Is it making any noise when you turn it?
All else checked it appears you have a bearing or race problem. I think you need a special took to press them in if I remember correctly.
Bump wrote:Do you have a damper?
Thanks Bump. No to all of those questions. When I went down it twisted the forks, not much. It rode fine back to the truck, and I have pushed it around before, no problem. Then this time, this hard to turn problem. Guess I won't know til I tear it apart. I hope I'm not hurting it turning the forks as I move it around.
Jim
river- XRR Jockey
start with simple stuff
untwist your forks
then
get the bike on a stand and check your steering head bearings
no idea about the 650R
but on each of my XR600s they were toast after a season
in two cases the cages broke and one by one the bridges got squshed between the cones
every time this happened the bike was absolutely unsteerable
the crash impact forced the bridge thru between the cones and flattened it to metal foil
then everything worked until the next piece broke loose and got stuck
untwist your forks
then
fiep- noob
fiep wrote:start with simple stuff
untwist your forks
then
Thanks. That might be what's going on. Will post when I get it apart......when my to do list gets down about 50 slots.
Thanks much.
Jim
river- XRR Jockey
Honda skimps on grease for the steering head bearing on all their bikes. The bearings might be toast from the fall( I doubt it). Either way it is a good idea to pull the steering head apart and grease the bearings. Then you can also inspect them for damage, align parts and torques them to proper specification. It sounds like it is a bigger job than when you actually complete the previously mention tasks.
Power washing is not a good idea. It forces water into bearing. A garden hose level of water pressure is better.
Similar topics» GSXR 100 forks fit on a Bandit 1200?
» Bike Week
» VERY URENT BIKE BOX PLEA FOR SAT 20/05/11
» Lets see your fav bike related pics
» Sa lahat ng umoorder ngayon kay TOP BOSS BIKE
» Bike Week
