Good Article On Case Saver and more
Post  Bump on Tue Mar 30, 2010 9:36 am
Borynack delivers again with this great and brief page on case savers:
http://borynack.com/XR650R/Cycle/difference_between_case_savers.htm
Re: Good Article On Case Saver and more
Post  rikco on Tue Mar 30, 2010 10:32 am
im about to install mine on the brp
its a selfmade saver by a well known member on xr forums
its a nice piece
now i dont have to worry about a broken chain
Nice piece!
Post  Bump on Tue Mar 30, 2010 11:51 am
Looks great. Just an FYI, Team Honda always ran the OEM guard. It works perfect with the 14 up front and a small amount of grinding is all that is necessary for a 15. IMHO, the key to safety here is to change the chain at regular intervals. Use the stock Honda chain too. You have to spend a lot of cabbage to beat the Honda chain.
I'm always amazed at the amount of preventable crashes and catastrophic failures of parts that are the result of running parts too long. Change cables, tires, chains, oil and so forth regularly. It's cheaper in the long run. The bike will be cheaper to maintain and be worth more when you sell it. Sell your used stuff for emergency spares.
Post  aisenauer on Fri May 07, 2010 3:11 am
hi there, I wish to make one similar,
could you kindly send me the draw of it 1:1 (original size) and its
various sizes, including thickness?
Can it be mount with 15 teeth sprocket? Of what metal did you made it?
thank you however
best regards
aisenauer
Post  surpriserider on Mon May 10, 2010 8:13 pm
has anyone seen one for a 16 tooth sprocket?
surpriserider
XR650R Year: 07 X2
Post  xrmanu on Wed May 26, 2010 2:50 pm
rikco wrote:im about to install mine on the brp
its a nice piece
hey hey hey ...
xrmanu
XR650R Year: '00
Post  xrmanu on Wed May 26, 2010 2:51 pm
surpriserider wrote:has anyone seen one for a 16 tooth sprocket?
Mine (the one on the pics above) fits with a 16.
xrmanu
XR650R Year: '00
Post  surpriserider on Wed May 26, 2010 5:09 pm
I was hoping to buy one because I have way too many projects already but it looks like I'll have to make one like yours. That's a nice looking case saver
surpriserider
XR650R Year: 07 X2
Post  rikco on Thu May 27, 2010 4:42 am
various
sorry but i dont do that cause i did not make it.
ask the man who make them and he can send you a draw of it for 50 dollar
