raising bars: clutch and decomp cable length problems?
Hey y'all,
I'm raising the bars a lot. Motion pro sells cables 3" longer than stock, but I can't find anyone who makes clutch and decomp cables 3" longer as well. Anyone have this problem? Is there another bike's parts that fit?
Thanks!
Jim
Thanks!
Jim
SFXR- XRR Jockey
Re: raising bars: clutch and decomp cable length problems?
I recently fitted a Mikuni carb and had to get new throttle cables made for higher bars.
Boats need a lot of cables made up so it could be worth asking local boat yards for cable makers. The other alternative is cable making kits and making one up yourself.
I managed to use the standard clutch and decomp cable by carefully rerouting it. Be sure the decomnp cable does not go tight on full lock as it cuts the engine.
Hew- XRR Jockey
PM pwrtrippin, he raised his bars 5+" He had to get custom cables done up.
2 in risers
I put 2 in risers and a set of Renthal hi bars on and rerouted the stock cables works fine.XX
dos equis- noob
No room with the big old Acrebis 6.3 Gallon tank. His was pulling the compression cable tight and causing the bike to stall. A real pain in the butt when you had to turn around in a tight spot.
Similar topics» Zafira A problems help!
» A shout out to the former cable Tv host known as "corona gorda"
» New Mesh in Clutch
» Riser bars
» fat bars helpppp
» Riser bars
» fat bars helpppp
