XR speedo
XR speedo
I'm in the process of getting the BRP street legal and needed a speedo. I'm not a fan of electonic meters so I adapted an XT225 speedo to the BRP--seems to be accurate will test against my GPS later. It does work and was relatively easy.
akasy- noob
I doubt they will even test it
And you won't use it much either! That said, it looks like a sano fit!
I might put a larger washer between the bold head and the bracket. Did you cut the bracket?
Re: XR speedo
Looks good, I went with the Baja Designs made in China one. I tried the used route (XL350)and ended up with a piece of junk that ended up getting returned.
Clipity- XRR Jockey
Speedo
Bump wrote:And you won't use it much either! That said, it looks like a sano fit!
I didn't have to cut the bracket but I did have to file a very small amount off the lip at its outer edge. I made a bracket to mate to the speedo's peg legs and bolted the bracket to the holes where the original trip meter bolts to the original bracket.
akasy- noob
Similar topics» speedo not working
» wheel and tyre size converter, is our speedo out??
» KOSO DB-01 SPEEDO SETUP
» Keller 25-4 F5D motor + 80 amp Kontronik speedo
» Speedo reading kicks up when I touch the brakes
