XR chain guide mod
XR chain guide mod
Post  xrmanu on Fri Oct 23, 2009 7:51 am
With the the OEM chain guide and my 5" Excel rim ,I had some clearance problems when I adjusted my chain to the second part of the chain adjustment range .I toke an old XR600 guide (they are all the same on the XR's) and did some cutting an adding a 32mm DRC chain roller on bearings.So no probs anymore: less (power) robbing/ drag and great clearance for the rim and full chain adjustment range. In Europe, Monobike racers remove the guide completely but I take my SM off-road now and than ,so I did something different. :ride: This mod should be good for chain life too. It works great on my Honda XR680R supermotard and it should work for light off-road/dual sport use also with the stock wheel.
Stock versus modded
DRC 32mm chain wheel
Before mounting. You need : chain wheel on bearings, OEM Honda bolt and nut, 2 washers ...
Voila. No drag,great clearance for the 5" rim. Should work great with 40 to 45 rear sprocket.
xrmanu
XR650R Year: '00
Re: XR chain guide mod
Post  Not for highway use on Sat Nov 14, 2009 6:00 pm
Smart thinking! Is your swingarm black?
Not for highway use
Post  xrmanu on Sun Nov 15, 2009 2:38 am
xrmanu
XR650R Year: '00
Post  aisenauer on Fri Oct 21, 2011 10:22 am
cool idea but, I was thinking, wouldn't be better to leave the front location to mount the wheel?
I mean, in your mod you did leave the rear location (facing forwards) to mount the wheel, the one nearer to the rear sprocket, I think maybe it's better to mount the wheel in the other position, looking at others off road bikes.
what do you think about?
aisenauer
Post  xrmanu on Sun Oct 23, 2011 5:35 am
If you place the roller in the front of the guide (left bolt) ,you still have the problem of the 5" rim touching it. Smile And destroy a nice Excel rim....
xrmanu
XR650R Year: '00
Post  aisenauer on Sun Oct 23, 2011 11:05 am
so this mod is useful only for motard configuration? I mean big rim and small rear sprocket?
But If I could do it for off wheels 18-21?
aisenauer
Post  rikco on Tue Oct 25, 2011 4:53 am
i only flexed a little piece of the chainguide on the back so it can not touch the rim, onfront it looks like a normal chainguide and it works fine but with the chainroller is nice to and im gonna make one like that in the future when i need a new one.
nice
Post  aisenauer on Sun Nov 27, 2011 1:02 am
@xrmanu, I tried to do that, but chain flowing on the roller is very noise! Too annoying...
what about yours?
aisenauer
Post  xrmanu on Sun Nov 27, 2011 1:10 am
What sprocket size are you running? Is the roller free to move?
xrmanu
XR650R Year: '00
Post  aisenauer on Sun Nov 27, 2011 1:27 am
rear sprocket is 44 or 45 teeth, I think noise is caused by the harder plastic of the roller (that can move easily), while the original is a little smoother...
Are you saying that yours don't make noise? Is your roller smooth?
aisenauer
Post  xrmanu on Sun Nov 27, 2011 1:50 am
I don't have any noise with a 40t sprocket... from 0 to 190 km/h.... BRP smile
I used a roller on bearings and have put washers between the roller and the slider to have free movement.
xrmanu
XR650R Year: '00
Post  bikerman on Sun Nov 27, 2011 4:42 pm
xrmanu nice mod, I will be doing the sm mod and I wil need this step, do you have the pics with some explanation how too do it, by the way post some pics of your sm please! could you also send your spec I want to have all the info I need to decide which way to go.
BM
bikerman
Post  xrmanu on Mon Nov 28, 2011 3:37 am
I think the first pics speak for them self. BRP smile
My bike: http://www.xr650rforum.com/t512-xr680-build-rebuild?highlight=xr680
xrmanu
XR650R Year: '00
