wp 4860 sxs forks on xr
Got a set of wp forks for the xr,has anyone got a heads up on what honda triple clamp assembly will be the go for the 650?,crf450?......60mm dia for the bottom triple,and has a xr/crf share 22mm offset?.Thanks
giantpiggy- noob
XR650R Year: 00 00 ktm660 rallye
Re: wp 4860 sxs forks on xr
I got the forks on the piggy,just a bit of work finish....got a set of cr500 triples,just had to press the piggy stem into the cr bottom t/clamp,going scotts dampner under bar with risers to get the height up,the cr has 24mm offset,just looking at the number under the piggy t/clamp maybe 19mm offset?....anyway piggy not known for turning traits,just aim and hope for the best sort of rig
giantpiggy- noob
Looks good! Got any other pics?
RallyMoto- XRR Jockey
Similar topics» wp 4860 sxs forks on xr
» Forks and oil
» K75 S forks on a K100 LT ??
» K1 Forks on a K1100 lt
» Enfield Front End / Forks on British Lightweights
» Forks and oil
