KTM Fan on the BRP
KTM Fan on the BRP
Post  modette on Sat Aug 15, 2009 4:54 pm
Here is the fan I ordered from www.ktm-parts.com, it fits up nicely. I then made a bracket out of Aluminum that I picked up at my local ACE Hardware store. It worked out really good. Still have to wire it up to a switch, but I am waiting for the Rectifier to come in from Baja Designs. Also as you can see I shaved part of the fan so the Acebis tank will fit nicely too without rubbing.
modette
http://www.cowrw.com
Re: KTM Fan on the BRP
Post  Focker on Sat Aug 15, 2009 7:29 pm
Looks good.
Here's more for those who are thinking of this mod...Great switch ideas etc.
radiator-protection
radiator-fan-install
Post  J_T on Mon Sep 14, 2009 12:45 pm
modette wrote:Here is the fan I ordered from www.ktm-parts.com, it fits up nicely. I then made a bracket out of Aluminum that I picked up at my local ACE Hardware store. It worked out really good. Still have to wire it up to a switch, but I am waiting for the Rectifier to come in from Baja Designs. Also as you can see I shaved part of the fan so the Acebis tank will fit nicely too without rubbing.
What is the thickness of this setup, I want to measure to see if it would fit with my Clarke 4.3 tank?
J_T
Post  modette on Mon Sep 14, 2009 1:52 pm
I have no clue...I thought I read over on ADVrider that it would not work with the Clark tank, I could be wrong though.
modette
Post  J_T on Mon Sep 14, 2009 1:55 pm
I read that as well which is why I was asking...Didn't know if it was slight enough to heat the tank and push it in a little like mounting the FCR carb or if it required too much. As well I don't know if I believe that it doesn't work since comparing to my stock tank... it doesn't protrude too much (just eye-balling it)
J_T
Post  babuja on Mon May 21, 2012 1:08 pm
Has anyone sucessfuly instaled a Ktm fan along with Acerbis 24L tanK?
babuja
Post  Focker on Mon May 21, 2012 1:55 pm
babuja wrote:Has anyone sucessfuly instaled a Ktm fan along with Acerbis 24L tanK?
Yes.
It worked for me and Hodakaguy!
Post  babuja on Mon May 21, 2012 2:02 pm
Yes.
Tnks Focker...did you guys have done any post about it?
babuja
Post  Focker on Mon May 21, 2012 2:46 pm
Not specifically for fitting it with that tank. There's a link above in my post with my fan install.
Post  BuRP Yesterday at 12:50 pm
It will not work with an IMS-tanker, my block on a dick - but you didn't ask that.
I know, but just so you know, I dunno the Acerbis but will take Focker & Hodaka's word for it.
This fan's a good idea, you won't regret it.
