Sub Frame is Cracked
Left Side:
Right Side:
But what can you expect from Honda I guess, they did not even completely weld around the insert, but they did that for the rear fender attachment *shrug*
It is off getting welded, the bro in-law knows a guy that does Aluminum. I think it will be done for free, if not just a fee bucks. It will be welded completely around the insert.
Right Side:
Unfortunately...
It looks like you got one of the Chinese XRRs from Wal-Mart.
Re: Sub Frame is Cracked
Looks like it will be done Sunday :-( I have not heard of cost from the brother in-law so I am hoping free. Although I owe him a meal for all the help he has given and more to come. I guess a steak at the old Steak Smith is in order.
Is going to be free, The Texas Roadhouse is acceptable (and cheaper). When you want to rewind the stator? Am I helping you do something tomorrow?
pwrtrippin- noob
Well I thought you had to come over and get a check (money the wife owes your wife I guess), I figured you could help with some of the little stuff. I got the rear fender put together. I plan to install the rear sprocket, the rear wheel spacers, install the temp sensor, run the RPM wire, change the coolant, change the oil & filter, install the new skid plate and other then the sub frame that will be it...oh remove the stator and you can take it to wind, and then Baja Design rectifier will be here Monday I believe. Oh yeah I guess I will get the Zumo GPS mount installed and see where that will work best.
So yeah if you want to come over there is plenty to do. If you could stop by Dave's and see if my toolkit is in, I already paid for it that would save me miles on the car consider he is next to your house. Give me a call, I'll be in the garage.
Possible cause of subframe failures.
After getting Modettes subframe welded up, the welder who is a FAA certified welder told me 90% of the welds on the subframe are coldwelds. (for those that don't know the terminology a cold weld while it looks good on the outside lacks penetration to the base metals giving it a weak weld). Maybe this is the reason behind the failures.
pwrtrippin- noob
Similar topics» frame questions
» Looking for stock frame for 58 XL
» Frame Number Info Please
» Full stock build! NO frame
» selling single bed-frame,canvas wardrobe & cupboard
