Chain adjustment
Chain adjustment
Post  Tattooart on Tue Apr 28, 2009 9:30 pm
I am sitting here as I just adjusted my chain and I am thinking that I have no idea what people are adjusting their chains to. So my question is this.
I have the bike on the stand with freeplay adjustment to 50mm will this be ok? What should it be? I am a little concerned because I have a friend that stripped out a c/s shaft.
Tattooart
Re: Chain adjustment
Post  Guest on Thu Apr 30, 2009 8:59 am
There is a sticker right on the swingarm next to where you are checking the freeplay that says to adjust to 25mm...
Guest
Guest
proper chain adjustment
Post  mamacone on Thu Apr 30, 2009 10:05 am
Stroupdog, passed on his words of wisdom awhile back, here you go. Squash down your suspension flat by using a ratchet strap across the seat until the swingarm is paralell to the ground then adjust the chain just shy of tight, that sould do it! Viola you're done! Remember to check the sitting on the stand tension right after you're done removing the strap. This is your chain tension, unique to you bike. Good day. Another trick is to sit on the bike backwards and check the chain, best if pig is not running.
mamacone
Post  Tattooart on Thu Apr 30, 2009 12:41 pm
pakolea wrote:There is a sticker right on the swingarm next to where you are checking the freeplay that says to adjust to 25mm...
I do not have that sticker but I do have the service manual and it says between 20-30mm. My friend adjusted to that spec and stripped out his counter shaft. So I will not adjust to that spec, just for that reason.
I was just trying to find out what the general consensus was on chain adjustment for these BRP's.
My 450x is easily adjusted and on the tight side with no problems. cheers
Tattooart
Here's what I've always done
Post  Bump on Thu Apr 30, 2009 1:44 pm
Get the bike on a stand. Put a box style wrench between the chain and the srear sprocket, and roll the wheel so the wrench goind around just a little. Adjust the chain tight, line up the wheel straight, tighten teh axle nuts, adjuster nuts, roll wheel in reverse and remove wrench. Should be right.
A friend just told me team Honda uses that in the pits.
What?
Post  mamacone on Fri May 01, 2009 8:15 am
Bump wrote:Get the bike on a stand. Put a box style wrench between the chain and the srear sprocket, and roll the wheel so the wrench goind around just a little. Adjust the chain tight, line up the wheel straight, tighten teh axle nuts, adjuster nuts, roll wheel in reverse and remove wrench. Should be right.
Can't quite follow, would like to see a picture doh
mamacone
Post  Focker on Fri May 01, 2009 10:50 am
mamacone wrote:Can't quite follow, would like to see a picture
I think what he's saying is tighten the chain with an obstruction...When you remove the wrench the proper slack will be left...Right?
Ed Zachary
Post  Bump on Fri May 01, 2009 11:18 am
Imagine a box end wrench got caught up in your chain and sprocket, resting in the concave portion of the sprocket, pinned my the chain. I'll look for some photos on the web. Didn't find one.
Ya know how you always were told to keep your fingers away from the bottom of the sprocket where the chain loads on? So imagine sticking a wrench in there and watching it go around the sprocket with the chain pinning it on. I'll take and post a photo later.
Focker has it correct.
