bolt sizes - help please!
Post  SFXR on Wed Apr 01, 2009 10:46 am
Making a trip to the hardware store soon. Could somone please tell me the correct sizes (head and thread) for
1. The stock skidplate bolts (4)
2. Gas tank bolts (putting 2 bolts thru acerbis tank and Tom's radiator guard). Need some rubber bushings too, apparently.
Also need the correct socket size for the left side flywheel. Gonna try to do the valves myself. study
SFXR
Who knows ...
Post  Bump on Wed Apr 01, 2009 2:51 pm
I've had some problems between what my bike is supposed to have according to the documentation, and what I find on it. So what I do when I have it apart is I take the bolts to a very good hardware store nearby and replace them with stainless, usually allen head. I'm trying to get everything similar so checking the fasteners before a ride is quick and simple.
I also do it for the stuff I add on to the bike if possible.
SFXR wrote:Making a trip to the hardware store soon. Could somone please tell me the correct sizes (head and thread) for
Re: bolt sizes - help please!
Post  Dave P on Thu Apr 02, 2009 11:43 pm
What Bump said. I'm finding interesting pieces-parts that need to be standardized.
The Service Honda site ( http://www.servicehonda.com/parts.html ) suggests the following:
Gas tank bolts:
Item 26, Bolt - Washer = 6x40 (part # 93404-06040-00)
The collars are an additional item.
Skid Plate bolts:
Item 26 (2) and 28 (2)
Item 26 is listed as "6mm," and 28 as "10x111."
Mine are all interchangeable, with various ferrules and washers to keep the plate from making annoying sounds.
Dave
Dave P
XR650R Year: 2002, 2001
Post  SFXR on Fri Apr 03, 2009 8:45 am
nice 2 thumbs right on! thanks Dave
SFXR
Gas Tank Mounts
Post  Bump on Fri Apr 03, 2009 11:44 am
For about the same money you can get the XRSONLY billet gas tank mounts. I'm not sure there is any advantage, and there could be a disadvantage, but I wanted you to know there's an option. I have a set but haven't installed them because I needed to modify my setup to accommodate a Renazco seat, 4.3 IMS tank, and Fluidyne radiators.
Also, I've had good luck buying fasteners online. I recently replaced the crappy and wrong bolts my Cycra hanguards came with for a set of nice stainless button heads. I called Cycra a few times and they never called me back. They simply shipped me the wrong fasteners. Wrong thread pattern. Losers.
SFXR wrote:nice 2 thumbs right on! thanks Dave
Post  Dave P on Sun Apr 05, 2009 11:00 pm
Man, go with the billet!!!!! BRP smile
Dave P
Post  SFXR on Mon Apr 06, 2009 9:13 am
OEM bolts for honda skidplate: $4.35 each x 4, +9.5% tax = $19.05!!! Shocked Just to mount a plastic skid plate! What are they, made of gold?!
Found some bolts at the hardware store that should help me attach the acerbis tank to Hodakaguy's brace. The trick is finding a washer/plug to keep the bolt heads from passing all the way thru the wide and oddly-shaped holes at the bottom of the acerbis tank. It's like I need a cork or something. Hey now ...!
good idea
SFXR
You just had to didn't you?
Post  Bump on Mon Apr 06, 2009 11:05 am
I knew it was just a matter of time until the SF jokes came out, so to speak. I got a buddy in Kansas who thinks I'm close enough to SF to call it SF!
And no, I don't know where you can get any San Francisco Reeboks!
SFXR wrote:OEM bolts for honda skidplate: $4.35 each x 4, +9.5% tax = $19.05!!! Shocked Just to mount a plastic skid plate! What are they, made of gold?!
good idea
Post  Trl_Rdr on Fri Jul 17, 2009 1:44 pm
This is what the Acerbis mounts look like:
Trl_Rdr
