Edekbrock Quicksilver
Post  Guest on Sun Mar 29, 2009 5:28 pm
Not sure if this has been covered before so here goes. I've been running the Quicksilver carb for quite a few years now and with the exception of the accelerator pump making it a bit stiff as you roll the throttle, I've been pretty happy with it. The issue now is that the rubber boot around the accelerator pump has deteriorated and needs to be replaced. Edelbrock wants to sell the whole plunger assembly for approx. $75.00 which is assanine when all I need is the boot that should sell for a couple bucks. Anybody else run into this or find a replacement somewhere else??
Sparky
Guest
Guest
