Where does this carb hose go?
Seems too short to vent down at the shock with the others. found it hanging loose and don't know where it goes -- help!
SFXR- XRR Jockey
Re: Where does this carb hose go?
thats just a breather hose isn't it? Route it down with the other ones
I'll confirm tonight if i remember
ADVJake- noob
Afternoon all, If i remember correct it fits onto the tank mount rubberÂ
Pikkos- noob
Pikkos wrote:Afternoon all, If i remember correct it fits onto the tank mount rubber
that's what i'm kinda thinkin. too short to route down to the swingarm. It seemed to up under the spine of the frame. is there a piece it plugs onto? or does it simply vent upward?
SFXR- XRR Jockey
There is a slot the right angle just slips in so the end is parallel to the frame
Pikkos- noob
After my jet work that hose is routed with the rest of the hoses.
Why its shaped weird i dont know
bakeray- XRR Jockey
Here's a pic of where i think it goes
Pikkos- noob
Thanks Pikkos. Just to confirm--it remains open-ended and venting to the air, yes? Or is it plugged at the end?
SFXR- XRR Jockey
Yes it's open it vents i presume it's up high if your in water and acts like a snorkle.
Pikkos- noob
Snorkle?
The carb is about the same level as the air box so it all goes wet near the same time. If you are dragging the vent hoses in water a lot, or if you are having a lot of problems in whoops or when riding at WOT with gas flow inconsistencies, then use what team Honda did and install the PC Racing air box vent. Easy to make also. Just T off on each of the two hoses going over the carb (an earlier factory attempt to fix the problem) and run the new line over to and into the airbox ending in some sort of foam filter. Seal it all up good now, ya hear? I think you gotta be ridng pretty damn fast to need this fix though.
I heard there was a secret works emulsion tube that some bikes had but have yet to see one or get my hands on one. And I've tried believe me!
If you are in a LOT of dust then get one of the carb vent hose filters from Jim Rios at BRP. Neat little device!
Similar topics» carb
» Where does this carb hose go?
» Just rebuilt the carb - PCV valve question
» mk4 golf mk4 1.8t rev''s!!!
» Need Carb Tuning Advice Again 8896 Holley 1050
