Second fuel tap on clark tank
Post  Pikkos on Mon Mar 09, 2009 12:08 am
Evening all, I think i've solved the fuel left in the left hand side problem.I installed an extra tap and it fitted good and the plastic seemed to be 2.5/3mm thick and the fitting dosn't leak at all i also made an adaptor on the fuel inlet to the carb here some pic's  http://cgi.ebay.com.au/ws/eBayISAPI.dll?ViewItem&ssPageName=STRK:MEWNX:IT&item=230294538835  ViewItem&item=230294538835&sspagename=STRK%3AMEWNX%3AIT&viewitem=[url=http://www.servimg.com/image_preview.php?i=37&u=13294344][/url]
Pikkos
Re: Second fuel tap on clark tank
Post  KTM265 on Thu Mar 12, 2009 10:36 pm
Nice, so it pulls from both sides, dumps into the T into 1 line which runs to the carb. Does the one side sitting lower then the carb still allow it to pull fuel?
KTM265
http://www.BucketRiders.com
Post  Pikkos on Thu Mar 12, 2009 11:13 pm
Afternoon  KTM265, The bike is "still"in the rebuild stage so i haven't rode it with the extra tap but looking at the level to the carb you will get 99%  of the fuel with a bit of a wiggle/shake. If you ride around that low on fuel I think you should take the bus instead.
Pikkos
Post  KTM265 on Tue Mar 17, 2009 7:44 am
There are times when the miles are just a little further then planned on beat head ...every drop counts at that point...
KTM265
