CUSH DRIVE
CUSH DRIVE
Post  wattsie on Mon Nov 21, 2016 9:33 am
Hi, If you have seen my intro I have a modified 2000 that is set up for long adventure style touring and in Aus that can mean 3-4 days of long sealed road to get to some of the more remote country no matter how much you try to do the side roads. On recent trips the cush drive has come up as a problem all dirt bikes that have a fixed sprocket suffer , damage to the driveline usually the gear box , I have read some comments saying the xr has a cush in the box but this is not true. Having looked through all the manuals . I have been running a sprung roller type chain adjuster which takes some of the whip out of the chain but feel a cush hub would be a lot better . wondering if anyone knows of a hub, wheel that will fit off something else with a bit of modification , not into buying top dollar after market gear . I have made all my racks and a 11 ltr aux fuel tank up fitted thermos, a lithium battery wired up charge points ,led day running light, padded out the seat all from fairly cheap alternatives, hoping to do the same for this. any ideas welcome . CHEERS Wattsie
wattsie
Re: CUSH DRIVE
Post  wassie on Mon Nov 21, 2016 10:07 am
G'day wattsie,
wassie from Brisbane
wassie
Re: CUSH DRIVE
Post  Mauser on Mon Nov 21, 2016 2:11 pm
Welcome Wattsie, cush drive is built into the clutch.... razz
Re: CUSH DRIVE
Post  wattsie on Tue Nov 22, 2016 5:43 am
Hi Wassie hope to get up that way possibly next winter starting to plan a trip to the cape will be talking more about this soon . Mauser thanks for the pic I'm taking it that is with the rivets drilled and the gear off , someone at a recent ride did say to me that it could be in the clutch ,now I know its there it helps but with it on that side of the motor it softens the blows between the crank and the gearbox not the wheel and the gearbox , this may be enough dampening to stop gearbox wear from long sealed road riding . Have you or anyone else had any problems with high road use , if not I won't have to do anything which suits me fine. CHEERS wattsie Ps hope your partner appreciates that tounge of yours
wattsie
Re: CUSH DRIVE
Post  Mauser on Tue Nov 22, 2016 7:36 am
Yes drilled rivets....doesn't show these rubbers on any parts diagrams...maybe try the new rubber split link that Burps running Frustrated
Re: CUSH DRIVE
Post  wassie on Tue Nov 22, 2016 7:53 am
Don't worry too much about the wear in the gearbox as a good knobby like a d606 takes some of the shock from the big banger. A sticky road tyre would be way worse for wear and I've heard no one complaining from the mototards.
wassie
Re: CUSH DRIVE
Post  wattsie on Tue Nov 22, 2016 8:34 am
Great thanks guys that saves me a lot of messing around. I am running heidy k scouts front and back and they work well for sealed, gravel ,dry rocky clay and sand but no serious mud yet which I have a set of Dunlop knobbies waiting to use . CHEERS
wattsie
Cush Hub from Motoxindustries
Post  dufasnz on Tue Nov 22, 2016 9:00 am
I have just ordered a complete set of SM wheels from Motoxindustries with a cush hub. Jim has been extremely helpful and is building a set with a different front wheel for USD forks. I think they make their own hub but don't quote me on that. They might send you just a hub and that wouldn't be too expensive, tell Jim, Craig from NZ sent you.
https://motoxindustries.com/products/Supermoto-Conversion-Kit-Cush-Hub
here is what I ordered:
Excel Rims 5" rear (Excel's add US$250 to the Warp9 price in the link above)
Cush Hub made to fit the XRR
Stainless spokes and nipples
320 floating Disk + bracket + rear disk
42 sprocket + DID chain
Continental Conti Attack SM 160/60-17 matching front
Shipping to New Zealand (not cheap US$250)
Total       US$2030
dufasnz
Re: CUSH DRIVE
Post  BuRP on Tue Nov 22, 2016 10:26 am
Mauser wrote:Yes drilled rivets....doesn't show these rubbers on any parts diagrams...maybe try the new rubber split link that Burps running
I'm running what ? ? ?
Re: CUSH DRIVE
Post  Mauser on Tue Nov 22, 2016 11:12 am
Rubber split link.....you said always use this type for added safety and to save your cases listen up
cush mted rear sprockets
Post  temporary kiwi on Mon Nov 28, 2016 9:03 am
just remembered that these are commonly available in nz thru "nzmx parts", may be an aid reducing drive train wear
Re: CUSH DRIVE
