Castrol power 1 racing 10/40 oil
Post  Jay69 on Wed Oct 05, 2016 5:25 pm
Has anyone else tried this oil?
Jay69
Re: Castrol power 1 racing 10/40 oil
Post  Mauser on Wed Oct 05, 2016 6:39 pm
I use Silkolene Super 4 10w/40 Semi Synthetic in mine listen up
Post  Jay69 on Thu Oct 06, 2016 8:40 am
Is it any good?
I'm topping mine up a lot
Jay69
Post  Mauser on Thu Oct 06, 2016 10:44 am
Never had any issues with it on my ZX12-R....the JR1300 my DT175 or the 650 Smile
Post  BuRP on Fri Oct 07, 2016 9:47 am
Castrol?
No me eh, not even in a padlock...... Evil or Very Mad
But ehh, you better look where the oil goes if you 'top up a lot'?
Overfilling, airbox/breather, or rings if not valve guides?
Post  flyy on Sat Oct 08, 2016 5:46 pm
I was using Silkolene comp2 SX.
I bought 20l of this on Ebay for £58.
http://www.ebay.co.uk/itm/291449598888?=p2060353.m1438.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Meets all the same standards. Smile
flyy
oil tests
Post  dufasnz on Fri Nov 25, 2016 3:16 am
Found this the other day from some gay quad bike forum when I googled oil review, its old but interesting. According to theses results we should be draining whatever junk we are running and pouring in the Amsoil goodness...
Dated, Aug 20 2009
Here are the results of the latest S.A.E testing for motorcycle oils. Some info missing...
Brand Viscosity Grade Base Batch Number
AMSOIL MCF 10W-40 Synthetic LB 22259
Bel-Ray EXS 0W-40 Synthetic AF1212
Castrol GPS 10W-40 Synthetic 3011020
Golden Spectro 4 10W-40 Syn/Petro Blend 13264
Lucas High Performance Motorcycle 10W-40 Syn/Petro Blend None indicated on containers
Maxima Maxum 4 10W-40 Syn/Petro Blend 16104
Mobil 1 MX4T 10W-40 Synthetic X2904
Motul 300V Sport 10W-40 Synthetic 20507/A/69093
Pennzoil Motorcycle 10W-40 Petroleum HPLA192024/12143
Royal Purple Max-Cycle 10W-40 Synthetic F02402
Torco T-4SR 10W-40 Synthetic 62395
Valvoline 4-Stroke 10W-40 Petroleum H104C2
AMSOIL MCV 20W-50 Synthetic LB 22355
Bel-Ray EXS 10W-50 Synthetic AF1319
BMW 15W-50 Synthetic 13286
Castrol GPS 20W-50 Syn/Petro Blend 3006260
Castrol V-Twin 20W-50 Syn/Petro Blend 4103005
Golden Spectro 4 20W-50 Syn/Petro Blend 13036
Golden Spectro American 4 20W-50 Syn/Petro Blend 11838
Lucas High Performance Motorcycle 20W-50 Synthetic None indicated on containers
Mobil 1 V-Twin 20W-50 Synthetic X22H4
Motul 300V Competition 15W-50 Synthetic 20407/A/69015
Pennzoil Motorcycle 20W-50 Petroleum None indicated on containers
Royal Purple Max-Cycle 20W-50 Synthetic H11402
Screamin Eagle Syn3 20W-50 Synthetic 0461301314
Torco T-4SR 20W-50 Synthetic L 58418 LORJB CR
Valvoline 4-Stroke 20W-50 Petroleum F294C1
Yamalube 4-R 10W-50 Syn/Petro Blend 2 x 1494451, 2 x 99071
1235*1515
Actual Viscosity Tests
AMSOIL MCF 10W-40 14.14 Yes
Bel-Ray EXS 0W-40 15.06 Yes
Castrol GPS 10W-40 15.09 Yes
Golden Spectro 4 10W-40 15.91 Yes
Lucas High Performance Motorcycle 10W-40 11.11 No
Maxima Maxum 4 10W-40 14.39 12.5 to <16.3 Yes
Mobil 1 MX4T 10W-40 13.92 Yes
Motul 300V Sport 10W-40 14.01 Yes
Pennzoil Motorcycle 10W-40 13.0 Yes
Royal Purple Max-Cycle 10W-40 13.33 Yes
Torco T-4SR 10W-40 15.03 Yes
Valvoline 4-Stroke 10W-40 14.94 Yes
(Note, Lucas Oil did not pass the minimum specs for actual viscosity)
AMSOIL MCV 20W-50 20.04 Yes
Bel-Ray EXS 10W-50 17.09 Yes
BMW 15W-50 18.15 Yes
Castrol GPS 20W-50 19.52 Yes
Castrol V-Twin 20W-50 19.22 Yes
Golden Spectro 4 20W-50 20.24 Yes
Golden Spectro American 4 20W-50 19.61 Yes
Lucas High Performance Motorcycle 20W-50 18.54 16.3 to < 21.9 Yes
Mobil 1 V-Twin 20W-50 20.9 Yes
Motul 300V Competition 15W-50 17.7 Yes
Pennzoil Motorcycle 20W-50 16.84 Yes
Royal Purple Max-Cycle 20W-50 19.79 Yes
Screamin Eagle Syn3 20W-50 20.3 Yes
Torco T-4SR 20W-50 19.5 Yes
Valvoline 4-Stroke 20W-50 18.14 Yes
Yamalube 4-R 10W-50 19.48 Yes
The results show that all of the oils tested except Lucas High Performance Motorcycle 10W-40 have initial viscosities consistent
with their indicated SAE viscosity grades. Those oils consistent with their indicated SAE viscosity grades are appropriate
for use in applications recommending these grades/viscosities
Ratings for Shear Stability from Best to Least (Rated on both 40W and 50W)
1. Amsoil
2. Bel-Ray
3. Golden Spectro 4
4. Mobil 1
5. Maxima
6. Castrol
7. Valvoline
8. Torco
9. Royal Purple
10. Lucas HP
4 Ball Wear Test Rating from Best to Least
1. Amsoil
2. Mobil 1
3. Motul
4. Torco
5. Maxima
6. Bel-Ray
7. Pennzoil
8. Lucas HP
9. Castrol\
10. Valvoline
11. Golden Spectro
12. Royal Purple
Gear Wear Rating from Best to Least
1. Amsoil
2. Bel-Ray
3. Maxima
4. Valvoline
5. Royal Purple
6. Lucas HP
7. Golden Spectro 4
8. Pennzoil Motorcycle
9. Castrol
10. Mobil 1
11. Motul
12. Torco
Oxidation Stability Rating from Best to Least
1. Amsoil
2. Mobil 1
3. Bel-Ray
4. Maxima
5. Torco
6. Royal Purple
7. Golden Spectro
8. Valvoline
9. Motul
10. Pennzoil
11. Lucas HP
12. Castrol
TBN and Cleanliness Results from Best to Least
1. Amsoil
2. Motul
3. Royal Purple
4. Torco
5. Golden Spectro
6. Mobil 1
7. Valvoline
8. Lucas HP
9. Pennzoil
10. Bel-Ray
11. Maxima
12. Castrol
Foaming Tendencies from Best to Least
1. Amsoil
2. Golden Spectro
3. Torco
4. Royal Purple
5. Lucas Motorcycle
6. Motul (Failed)
7. Castrol (Failed)
8. Maxima (Failed)
9. Valvoline (Failed)
10. Pennzoil (Failed)
11. Bel-Ray (Failed)
12. Mobil 1 (Failed)
Rust Protection Results from Best to Least
Amsoil, Mobil 1, Motul, Torco, Maxima and Lucas HP all tied and passed with 0 spots.
Royal Purple, Pennzoil, Golden Spectro, Valvoline, Bel-Ray and Castrol all failed with 21+ rust spots present.
The following areas were all evalutated:
Wear Protection (4-Ball ASTM D-4172)
High Temperature/High Shear Viscosity
(HT/HS ASTM D-5481)
Gear Performance
(FZG ASTM D-5182)
Oxidation Stability
(TFOUT ASTM D-4742)
Rust Protection
(Humidity Cabinet ASTM D-174
Foam Control (ASTM D-892)
Volatility (NOACK ASTM D-5800)
Viscosity Shear Stability (% Viscosity
Retention after 90 cycles, ASTM D-627
Viscosity Index (ASTM D-2270)
Acid Neutralization (TBN ASTM D-2896)
Zinc Levels (ppm ICP)
Pricing
The overall ranking of all oils tested in the aforementioned tests is as follows:
1. Amsoil
2. Mobil 1
3. BMW
4. Torco T 4SR
5. Golden Spectro 4
6. Screamin Eagle Syn3
7. Golden Spectro American 4
8. Royal Purple Max Cycle
9. Motul 300V
10. Bel-Ray EXS
11. Valvoline 4 Stroke
12. Lucas HP
13. Pennzoil Motorcycle
14. Yamalube 4-R
15. Castrol GPS
16. Castrol V-Twin
Sources:
JASO T 904-98
ASTM Test Methodology Designation: D 892-03
ASTM Test Methodology Designation: D 1748-00
ASTM Test Methodology Designation: D 2270-04
ASTM Test Methodology Designation: D 2896-03
ASTM Test Methodology Designation: D 4172-94 (Reapproved 2004)
ASTM Test Methodology Designation: D 4742-02a
ASTM Test Methodology Designation: D 5182-97 (Reapproved 2002)
ASTM Test Methodology Designation: D 5481-04
ASTM Test Methodology Designation: D 5800-00a
ASTM Test Methodology Designation: D 6278-02
dufasnz
Post  JRZ7285 on Fri Nov 25, 2016 3:57 am
Interesting results Dufasnz! I use too run shell rotella then switched too Amsoil on recommendation from a fellow rider this past summer and noticed my shifting is smoother and engine runs strong and pulls hard IMO i just run what i feel is good for my bike and change oil accordingly and wont substitute for the commercialized oils! the Amsoil i run is pic below
JRZ7285
Post  dufasnz on Fri Nov 25, 2016 7:22 am
I've been looking into buying a 5 gallon (19L) Maxima Pro Plus 10W40 as its kind of middle of the road and affordable. I can't find the Amsoil in big pails/drum only small quantities at ridiculous prices and I'm sick of constantly buying small containers. I just a brought 57L drum of Automatic transmission fluid to run in my CR500, works out at about NZ$3.10 an oil change. Also got a Maxima 2 stroke oil 5 gallon pail, it works out much cheaper than buying 1L bottles and you have it on hand instead of realising just before a ride you forgot to buy some.... I am an expert at doing this beat head
I have always worked to the theory that reasonable oil changed frequently is better for your engine than expensive oil left in for ages. My Toyota Landcruiser is testament to that, I have doubled the torque output of its 26yr old 4.2L diesel engine to around 700Nm and its done 336,000km. I change the oil + filter every 6000km with cheap Valvoline and she purrs. It surprises every petrol head that gets in it!!
dufasnz
Post  Mauser on Fri Nov 25, 2016 7:43 am
Oil is cheap, I change it ever 1000 miles on the road bikes and every 6 months on the dirt bikes....roughly 500 miles cannot be exact as no odometer fitted lol....also pop a new OEM filter in....never check oil levels just fill up with what the book says.... razz
Post  JRZ7285 on Fri Nov 25, 2016 2:49 pm
dufasnz wrote:I've been looking into buying a 5 gallon (19L) Maxima Pro Plus 10W40 as its kind of middle of the road and affordable. I can't find the Amsoil in big pails/drum only small quantities at ridiculous prices and I'm sick of constantly buying small containers. I just a brought 57L drum of Automatic transmission fluid to run in my CR500, works out at about NZ$3.10 an oil change. Also got a Maxima 2 stroke oil 5 gallon pail, it works out much cheaper than buying 1L bottles and you have it on hand instead of realising just before a ride you forgot to buy some.... I am an expert at doing this beat head
I hear ya Dufasnz i did like the convenience of the shell rotella as its available just about every store around and at only U.S.$12.00 a gallon opposed too Amsoil which is U.S.$11.00 a Qt/L and i have too drive 10 miles out of town too only retailer that carry's it! I usually buy 3 bottles 2 for the bike and extra just in case for top off which i never need(so i really only buy 2 next time around as i still have extra one)! I only change my oil in the big pig once a year so spending a little extra money on the Amsoil doesn't bother me much just the wife mad as heck BRP smile
JRZ7285
