Any one found a use for Motoz mountain Hybrid Tyre
Post  forestgrump on Sat Nov 14, 2015 3:43 am
Has anyone run a Motoz Mountain Hybrid Tyre on the asphalt or gravel roads on a BRP. I can't make mine work on any bike yet. Honda CRF 450X or Gas Gas 300XC. 3lbs to 12lbs. Doesn't work. Forest
forestgrump
Motoz Mountain Hybrid Trials Tyre
Post  forestgrump on Sat Jan 30, 2016 3:50 am
HEH, I actually found a use for this tire. Mounted in on the back of 01 BRP. 28psi for now.
Gravel roads, works great.
Lose gravel roads, Not to bad seems quite controllable.
Hard Pack Gravel, works great, even with slime on top, temps in the 40's.
Asphalt roads, good manners, sticks real well.
Braking, In the looser gravel, locks up fairly easily, asphalt, not bad. But that's what they make a transmission for to slow you down.
Wear, seems to be wearing fine so far. But only have 250 miles on it. Forest
forestgrump
Re: Any one found a use for Motoz mountain Hybrid Tyre
Post  forestgrump on Tue Jun 14, 2016 8:36 pm
Well been experimenting with air pressure with Motoz Mountain Hybrid. Been slowing dropping air pressure to gain more traction. Works great at 8psi on asphalt, tire running warm with temps in the high 70's. Much better traction on gravel roads and improved braking as well. Still controlled in corners while flat tracking. As temps get warmer ( 90's), I'll probably bump it up 2psi to keep tire temps from getting to hot in summer. Seems to be wearing like iron. It's hard to keep from spinning it on gravel. Too much torque! Forest
Gearing 15/45
forestgrump
Post  PeteN95 on Tue Aug 16, 2016 8:33 pm
Anchor?! Seriously those tires are very heavy! My buddy said he liked the Kenda Equalibrium better too.
PeteN95
XR650R Year : '02
Post  forestgrump on Mon Sep 19, 2016 3:55 am
I have a Kenda Equilibrium on my 2014 GasGas 300xc and love it, didn't know they were DOT legal? Forest
forestgrump
