Spoke replacement
Spoke replacement
Post  wassie on Wed Sep 30, 2015 9:12 am
I need to replace a couple of spokes in the rear wheel of the BRP. Both spokes are on the inside of the left side, I've got the nipples off. Question is how do you get them out?
wassie
Re: Spoke replacement
Post  Mauser on Wed Sep 30, 2015 7:12 pm
Unlace them ?....might have to take any in front out of the way BRP smile
Post  BuRP on Thu Oct 01, 2015 1:30 pm
Don't understand the Q Wassie, if the nipples are off then just take them out.... however, you obviously will need to strip the wheel of the sprocket if not disc.
Post  wassie on Thu Oct 01, 2015 2:03 pm
The ends on the spokes coming out hit the spoke behind it. I've taken the nipple off that one and moved it around but still no room. What am I missing here Frustrated
wassie
Post  wassie on Fri Oct 02, 2015 1:00 pm
Problem sorted. The damaged spoke had a slight bend in it down close to the hub which wasn't allowing the spoke to clear the spoke behind, a little persuasion did the trick.And like BuRP stated I had to undo the two outer spokes forward of damaged one. Thanks for your interest
Bananatool
wassie
