XR No 5
Page 4 of 5 Previous  1, 2, 3, 4, 5  Next
Re: XR No 5
Post  Mad Frosty on Thu Jul 31, 2014 11:21 pm
You are brave , i would just take it to bits for the spares , but thats me .
Re: XR No 5
Post  Mauser on Fri Aug 01, 2014 8:37 am
Mad Frosty wrote:You are brave , i would just take it to bits for the spares  , but thats me .
I would have completly rebuilt it as a project, powder coated frame etc I have a newish set of off-road wheels with OEM tyres in the garage along with a loom, switch gear, stator, headlight etc  BRP smile bikes never seem to pop up locally for me !!!
Re: XR No 5
Post  B45HER on Fri Aug 01, 2014 12:31 pm
Wasn't local for me I'm in south Wales.. Anyway not all good news. Needs a cam and rocker arms at least.. Not sure what to do with it now. Put it on the back burner for a bit..
B45HER
Re: XR No 5
Post  beaver350 on Sat Aug 02, 2014 8:44 am
Do the cam and rockers typically wear out or was this bike neglected/not serviced.My old XR500 1982 lasted 20 years with original cam and rockers.
beaver350
Re: XR No 5
Post  Mauser on Sat Aug 02, 2014 9:19 am
There good engine and not known to wear anything if looked after, your lucky on your 500 most engines won't last with no or little oil.... BRP smile
Re: XR No 5
Post  Mad Frosty on Mon Aug 04, 2014 12:10 am
If you decide to sell some parts from it i am after the whole wiring harness/loom including the cdi and ignition coil , it could be the US or the Euro model .
Re: XR No 5
Post  Mad Frosty on Mon Aug 04, 2014 12:12 am
Mauser do you know if Paul has any spare parts left ?
Re: XR No 5
Post  Mauser on Mon Aug 04, 2014 8:29 am
Mad Frosty wrote:Mauser do you know if Paul has any spare parts left ?
He has just brought another 2 bikes...one was off-road use only...you know the type without any meaningful numbers....somehow having a CRF450 frame number won't get it on the road lol....I jest you not and the second is a nice SM full bike. Don't get your hopes up as Paul has several frames with V5's which I'm sure he intends to build up...if you after a loom email the guy on ebay breaking a US spec machine...called AndyBox cannot guarantee anything about him you take your chances lol....Paul's ringing me today I will ask him about your bits and see what he says....why would you want a lovely US spec wiring loom, they don't fit into the stator and from memory I don't think they plug directly into the US regulator...but not 100% sure on that just rember the plug on the UK might have an extra earthing point where as the US doesn't need it...not a big job but worth noting  listen up
Re: XR No 5
Post  BuRP on Mon Aug 04, 2014 12:37 pm
Mauser wrote:There good engine and not known to wear anything if looked after
Yay & Nay.... they will fail if one habitually starts it to impress whoever is within a radius of a mile, ie wide-open revving the thits* of it! Do that and witness the camlobes eating the rockers, simply because there's no oil there yet. It takes a surprising long time to get oil there, on some engines (I won't mention Ducati here, no, not me...) several minutes even.
This also is the reason why on some heads a 'cup' is designed in the casting, right under the lobes - to hold & retain oil, purely for those who start their engines the loony way.
* Thits yes, same as Bhoobs  BRP smile
Re: XR No 5
Post  Mad Frosty on Mon Aug 04, 2014 11:31 pm
I think there is something wrong with my electrics , the green wire comming from the ignition coil to the CDI looked bit coroded in the connection point so i decided to change it just to find out that its all black under the insulation it looks like it is burnt , and now the bike does not start  beat head , so the ignition coil or the CDI its toasted or both  tears
Re: XR No 5
Post  B45HER on Wed May 20, 2015 8:33 pm
Hello again, been a while.  So I sold the XR I built and kept the cheap nasty one and have done nothing with it until the last few weeks.  Frame etc have been sent off for powder coating (again) and I had a go at rebuilding the top end of my motor which is nearly done.  Just waiting on cam bearings and I can put it all back together.
I will get some more pictures when I get the frame etc back.
B45HER
Re: XR No 5
Post  Mad Frosty on Thu May 21, 2015 7:29 pm
You love it dont you BRP smile
Re: XR No 5
Post  B45HER on Thu May 21, 2015 8:15 pm
Mad Frosty wrote:You love it dont you BRP smile
I do enjoy it yes BRP smile
B45HER
Re: XR No 5
Post  B45HER on Sat May 23, 2015 8:44 am
Motor is done just waiting on the covers from the powdercoater, and the rest of it too.
Also bought myself a cheap blast cabinet, I was going to try make one but this was cheap so went with this.
Should help with the rest of the crusty mess. Got some soda already so will have a go next week when it arrives.
B45HER
Re: XR No 5
Post  Mad Frosty on Sat May 23, 2015 10:24 pm
Keep us updated , oh and what is the list of work to the engine ? Bananatool
( sorry i have mechanical sort of fetish Embarassed )
Re: XR No 5
Post  B45HER on Sun May 24, 2015 9:51 pm
It had new rockers and stage 1 cam, checked the valves, piston and cylinder. Everything else looked mint so left it as it was.
I need measurements from a rear wheel to see how much the sprocket side differs from disc side to the rim to build my rear wheel if anyone can measure for me please.
B45HER
Re: XR No 5
Post  BuRP on Tue May 26, 2015 11:51 am
Mad Frosty wrote:( sorry i  have mechanical  sort of fetish Embarassed  )
Would this perhaps involve hammering, screwing, nailing and the like?
If any of the aforementioned turns you on pls find another forum, I'd suggest Carpentry or General Woodwork.... razz
Re: XR No 5
Post  B45HER on Thu May 28, 2015 3:07 pm
Had one of my covers back from powder coating and painted the exhaust header pipe..
B45HER
Re: XR No 5
Post  B45HER on Mon Jun 22, 2015 6:35 pm
Frames back
Also done a diy oil sight tube while it's all apart
B45HER
Re: XR No 5
Post  BuRP on Tue Jun 23, 2015 11:45 am
Nice..... and now tell us what's in the biiiig Honda box?
Re: XR No 5
Post  B45HER on Tue Jun 23, 2015 12:54 pm
BuRP wrote:Nice..... and now tell us what's in the biiiig Honda box?
Nothing exciting I'm afraid, NSC50 scooter
B45HER
Re: XR No 5
Post  BuRP on Wed Jun 24, 2015 8:10 am
Daayumm...
was hoping to hear you've got an unopened crate containing a virgin pristine 2007 Piggie banana
Oh well, we all dream BRP smile
What's your plans once finished, will you flog it again or ride it for a change? Bump
Re: XR No 5
Post  B45HER on Wed Jun 24, 2015 10:38 am
BuRP wrote:Daayumm...
Now that would be nice, I did have one of the last new ones that came through the shop, but that was ages ago.
Haha funny enough I would like to ride this one! Only sold the last one because I had this one. So far it owes me less than £1000 with all the work and parts.. So far!
B45HER
Re: XR No 5
Post  B45HER on Wed Jun 24, 2015 10:45 am
B45HER
Re: XR No 5
Post  BuRP on Wed Feb 01, 2017 12:46 pm
OK B45HER,
now pls tell us what happened since? Bump
Re: XR No 5
Post  B45HER on Thu Jul 20, 2017 11:13 am
BuRP wrote:OK B45HER,
Hello again, bike got stolen 2 years ago so had a dabble with a few other bikes and ended up with another XR.. will post some pics up soon
B45HER
Re: XR No 5
