Stiffer springs
Stiffer springs
Post  Chris_w_65 on Wed Sep 04, 2013 8:57 am
My bike is a motard (Yes, it is an R Mauser, not an L).
I have all my suspension springs out and want to get stiffer springs made - I know the front are 4.3kg and I believe the rear is 9.2kg.
What should I upgrade them to for a motard for street and track use?
Chris_w_65
Re: Stiffer springs
Post  Chris_w_65 on Wed Sep 04, 2013 9:29 am
I am thinking maybe 15% - so 4.95 front and 10.6 rear
BTW, I weigh about 180 pounds
Chris_w_65
Re: Stiffer springs
Post  Mad Frosty on Wed Sep 04, 2013 11:27 pm
49 for the front and 11,5 for the back .
Re: Stiffer springs
Post  Chris_w_65 on Wed Sep 04, 2013 11:34 pm
Mad Frosty wrote:49 for the front and 11,5 for the back .
Thanks, I will let the guys know - They will come back to me tomorrow to let me know if they can make them and the price.
When I assemble the forks what weight oil should I use?
I think I will leave the valving for now, at a later date when I have learned to corner properly (and how rebound and damping works) I will strip front and rear and modify valving if necessary (not opening the rear this time).
Chris_w_65
springs
Post  temporary kiwi on Thu Sep 05, 2013 12:55 am
ive just got a set of .49 f/springs, and a11.5kg shock spring set up for my brp, have just sent my fork valves to a local suspension guy [ who actually runs a brp]hes going to revalve them to suit my weight[200pds] + the h/d springs
Re: Stiffer springs
Post  Chris_w_65 on Thu Sep 05, 2013 7:26 am
Anyone have advice on oil weight and valving for me? I will go for 49/11.5
As mentioned, the rear shock has not been stripped but I can pull it apart if need be.
Chris_w_65
Re: Stiffer springs
Post  BuRP on Thu Sep 05, 2013 2:49 pm
Borynack prescribes 2.5W, thin & difficult to get hold of - but I did. Have to do mine still but you also know the B-mod's reputation.
Re: Stiffer springs
Post  Chris_w_65 on Thu Sep 05, 2013 3:12 pm
Is 2.5 for plush desert racing or stiff road?
Chris_w_65
Re: Stiffer springs
Post  BuRP on Thu Sep 05, 2013 3:34 pm
Neither.
The shimstack in combination with the oil-weight determine the characteristics, and his stack clearly works well (offroad) with a 2.5 weight oil.
I'm sure one could design a stack suited to work with SAE40 also, only this kind of weight one won't find as shock oil I'm sure BRP smile
Why don't you contact Foxi on WildDogs? He knows his stuff, East Coast though.
FORK OIL
Post  temporary kiwi on Sat Sep 07, 2013 10:59 am
ATF IS AROUND 5WT HYDRAULIC FLUID
Re: Stiffer springs
Post  Chris_w_65 on Sat Oct 05, 2013 10:26 pm
I had loads of shock oil on the floor and myself today - I think next time it will be easier to bleed a rear shock now that I have done it once
Chris_w_65
Re: Stiffer springs
Post  PeteN95 on Fri May 02, 2014 10:44 pm
Just installed an 11kg rear and .49 front springs with 5wt oil in the fork. What a difference! Although maybe a bit stiff, but I ride mostly street and gravel. I weigh 225lbs.
PeteN95
XR650R Year : '02
Re: Stiffer springs
Post  Chris_w_65 on Sat May 03, 2014 5:48 am
PeteN95 wrote:Just installed an 11kg rear and .49 front springs with 5wt oil in the fork.  What a difference!  Although maybe a bit stiff, but I ride mostly street and gravel.  I weigh 225lbs.
\nice - Where did you get the springs and how much? Did you revalve?
Chris_w_65
Re: Stiffer springs
Post  Mad Frosty on Sun May 04, 2014 12:10 am
I have tryed  the stock 9,2 , aftermarket 10,5 , 11 and 11,5 ,  i have left the 11 in as it felt the best , and kept the 11,5 for when i load the bike for my planned trips  ,
on the front side i am on the 49 kg rated spring as that was the hardest i could get  , still too soft for me but big improovement over the stock spring , 53 kg would be ideal but the only way to get one would be a custom made spring  Evil or Very Mad
stiffer springs for sale
Post  temporary kiwi on Tue May 06, 2014 12:57 am
ive got a 11.5 rear, .49 fork- [ beat head  beat head  beat head  actually .47] srings for sale if anyone wants them, i need softer springing to go with my revalved suspension, these are suposed to work for a 90-95kg rider, id take $120 nz, cost me in excess  of $300
,sorry guys just noticed the fork springs are .47kg - not .49kg
Last edited by temporary kiwi on Wed May 07, 2014 12:16 am; edited 1 time in total (Reason for editing : wrong info supplied)
Re: Stiffer springs
Post  BuRP on Tue May 06, 2014 10:20 am
Mauser, Chris' bike is not an L neither an R.......... it is an M, from Motard - or Moron, and yes, I did tell Chris this in person!! A to-tal waste of a superb bike, the man is doing all & sundry to it, even fitting R1 zorsts under the seat I believe!
Help me convince him he should mount knobblies to it? After all supermotos ride on dirt too, he actually may find this is more of his liking than tar  BRP smile Bump
Re: Stiffer springs
Post  Chris_w_65 on Tue May 06, 2014 10:58 am
BuRP wrote:Mauser, Chris' bike is not an L neither an R.......... it is an M, from Motard - or Moron, and yes, I did tell Chris this in person!! A to-tal waste of a superb bike, the man is doing all & sundry to it, even fitting R1 zorsts under the seat I believe!
XR650SMR - only 1 zorst and here is the outlet
Chris_w_65
Re: Stiffer springs
Post  PeteN95 on Tue May 06, 2014 10:45 pm
Chris_w_65 wrote:\nice - Where did you get the springs and how much? Did you revalve?
Ebay and no, not yet.
PeteN95
XR650R Year : '02
Re: Stiffer springs
