XR650R engine power output
Post  Chris_w_65 on Fri Aug 16, 2013 9:04 pm
Stock crankshaft power on an BRP is 61.5HP - what do they push on the rear wheel standard (not corked)?
What kind of difference do all the following mods make?
HRC cam
Ported head
11:1 piston
Full aftermarket exhaust
Airbox side cover cut out
TM40 carb
Just wondering what I can expect when she is built Very Happy
Chris_w_65
horse power
Post  temporary kiwi on Sat Aug 17, 2013 12:33 pm
stock uncorked 45-48hp,most with these mods seem to be around 55hp
Re: XR650R engine power output
Post  BuRP on Sat Aug 17, 2013 12:42 pm
Let's start with the beginning Chris, your std indicated output is forking optimistic. If you get that after assembly be glad, but better brace yourself for less than that... really.
(Edit: seems Kiwi & me posted this in the same second, so now there's 2 who warn you not to be overly optimistic)
Post  Chris_w_65 on Sat Aug 17, 2013 3:55 pm
BuRP wrote:Let's start with the beginning Chris, your std indicated output is forking optimistic. If you get that after assembly be glad, but better brace yourself for less than that... really.
I was quoting crankshaft power - Is 61.5 not correct?
Chris_w_65
Post  Chris_w_65 on Sat Aug 17, 2013 3:56 pm
temporary kiwi wrote:stock uncorked 45-48hp,most with these mods seem to be around 55hp
Is that on the back wheel? 55 sounds good to me - pity I am at 5000 feet beat head
Chris_w_65
Post  Mauser on Sat Aug 17, 2013 6:42 pm
From what I can gather about Dyno's you can get different readings from different Dyno stations for the same bike & conditions......wouldn't pay too much attention to the numbers as long as she runs well be happy Bump
rwhp
Post  temporary kiwi on Sun Aug 18, 2013 6:14 am
yes , my previous eng setup had somewhere around that figure with - 12.5:1 std bore size piston, xrs only hrc copy cam, oversize valves, ported head, twin wrap around headers[long step pipe type]std carb with k&n std airbox replacement filter,[ derestricted] std ign, it wasnt dynoed but it had no trouble keeping up with 450's off the turns, then past them down the straights
crank to wheel hp
Post  temporary kiwi on Sun Aug 18, 2013 9:30 am
ive just seen a dyno chart put up on tt that says you can have 58hp at rear wheel std[ yeah right!] his dyno tuner has tweaked the settings, as it also got max power[67rwp] at 9800rpmand continued revving to10500rpm with just a pipe and power commander, these sort of figures are ridiculously inaccurate, just goes to show you can get any figure with the right fella at the controls, honda states 61ps at the crank, however it loses 14-16hp getting to the rear wheel
Post  Chris_w_65 on Sun Aug 18, 2013 9:34 am
I believe the XR650L pushes 44 at the CS but only 28 at the rear wheel
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 10:12 am
Chris_w_65 wrote:I believe the XR650L pushes 44 at the CS but only 28 at the rear wheel
And I am really enjoying the XR650L I am riding at the moment - Can't wait to ride my BRP
Busy sorting my parts into piles for zinc plating, spray painting, anodizing and powder coating Very Happy
Chris_w_65
Post  PeteN95 on Tue Aug 20, 2013 10:23 pm
Mine stock and uncorked was 45HP and 39ft/lbs. Here is the dyno run after a Leo Vince header and Stage 1 Hot Cam.
PeteN95
XR650R Year : '02
the unbeleivable becomes beleivable
Post  temporary kiwi on Tue Aug 20, 2013 11:18 pm
temporary kiwi wrote:ive just seen a dyno chart put up on tt that says you can have 58hp at rear wheel std[ yeah right!] his dyno tuner has tweaked the settings, as it also got max power[67rwp] at 9800rpmand continued revving to10500rpm with just a pipe and power commander, these sort of figures are ridiculously inaccurate, just goes to show you can get any figure with the right fella at the controls, honda states 61ps at the crank, however it loses 14-16hp getting to the rear wheel
guy just posted that its a ninja 650r twin, now the graph makes sense, like the one above
