Another problem, too little oil in gearbox ... after rebuilt
Page 2 of 3 Previous  1, 2, 3  Next
Re: Another problem, too little oil in gearbox ... after rebuilt
Post  Mauser on Sun Aug 18, 2013 1:37 pm
Chris_w_65 wrote:I see the bolt in your cover - turn it around and you will see the head and sealing washer
But the picture you have shown is NOT a 650R clutch cover or 650L cover....confused
Post  Chris_w_65 on Sun Aug 18, 2013 2:44 pm
Mine is same as yours
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 3:24 pm
My casing has an independant gold coloured clutch cover that can be removed - yours looks like a one oiece unit - Mine is a 2003
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 3:25 pm
Mauser wrote:Am I missing something here......here is my clutch cover ?.
Don't look like anything above Frustrated
And here's the 650L cover....
What is that bolt about 35mm above the kichstart bearing? Mine looks worn so I ordered one. Honda lists it as a special bolt. 90041-MBN-670
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 3:39 pm
Chris_w_65 wrote:My casing has an independant gold coloured clutch cover that can be removed - yours looks like a one oiece unit - Mine is a 2003
I see you also have a removable magnesium cover - it says so on the inside just like mine.
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 4:15 pm
Speaking of clutch covers - I am going to get gold paint matched - it is automotive Kapsci body paint + premium hardener - Will it stand the heat?
Chris_w_65
Post  Mauser on Sun Aug 18, 2013 5:14 pm
I have no idea never messed with it....you have still not explained why the picture shown is not a 650R clutch cover ?......Bananatool
Post  Chris_w_65 on Sun Aug 18, 2013 5:29 pm
My photo is taken from the outside - yours is from the inside
Chris_w_65
Post  Chris_w_65 on Sun Aug 18, 2013 5:35 pm
Here you go - my casing same as yours with 8mm threaded hole
Chris_w_65
Post  Mauser on Sun Aug 18, 2013 5:53 pm
Chris_w_65 wrote:Here you go - my casing same as yours with 8mm threaded hole
No your casing isn't the same as mine it looks nothing like it....stop messing about and get a 650R bike.
Post  Chris_w_65 on Sun Aug 18, 2013 6:46 pm
What is this?
Chris_w_65
Post  Hew on Sun Aug 18, 2013 6:51 pm
I can't believe it I even had to go and have a look in the garage and by fluck mine has mine too
Just below and to the right of the kickstart. Never used it and it certainly is no oil level screw.
Post  Chris_w_65 on Sun Aug 18, 2013 7:19 pm
Makes sense if your scavenge pump were faulty oil would run out of it
Chris_w_65
Post  Mauser on Sun Aug 18, 2013 7:56 pm
Hew wrote:I can't believe it I even had to go and have a look in the garage and by fluck mine has mine too
Hew your a pretty normal guy tell the others that the picture of their clutch case isn't a 650R it's from another bike !!!!
Post  BuRP on Sun Aug 18, 2013 11:15 pm
'Course it is, just take the cover off the cover...
Post  Chris_w_65 on Mon Aug 19, 2013 5:20 am
BuRP wrote:'Course it is, just take the cover off the cover...
Or look at the hondaparts-direct.com link I posted higher up with the part numbers:bananatool:
Chris_w_65
Post  AURORA on Mon Aug 19, 2013 5:43 am
Chris_w_65 wrote:Here is the oil level check bolt reffered to by the OP
I am not saying it is for checking oil level but it does exist - its purpose might be to check the scavenge pump is working properly??
It is an XRR cover.
Post  Chris_w_65 on Mon Aug 19, 2013 5:49 am
It is an XRR cover.
A dirty XRR cover - but not for long
Chris_w_65
Post  Mauser on Mon Aug 19, 2013 9:11 am
I must be losing the plot, I didn't realise and even looking at the drawings that the right crank case cover is in 2 parts, the main section which is clearing shown on the drawing and the rear part which doesn't seem to have a part number ?.
I appologise to you all for being a noob and will shut up for the next 12 hours....razz
Post  Chris_w_65 on Mon Aug 19, 2013 9:15 am
Mauser wrote:I must be losing the plot, I didn't realise and even looking at the drawings that the right crank case cover is in 2 parts, the main section which is clearing shown on the drawing and the rear part which doesn't seem to have a part number ?.
I was starting to think you had a Chinese knock off (Chonda XR650R) parked in your garage StirPot
Chris_w_65
Post  BuRP on Mon Aug 19, 2013 11:34 am
Nope, but Mauser drinks tea Chris, so I suspect he had a bit of an alien leaf in there... BRP smile
No worries Maus', I've been seen pouring coffee in the sugar, we all have blonde moments. And don't overdo it pls, 12 hours is a looong time to go celibate razz
Post  Chris_w_65 on Mon Aug 19, 2013 4:30 pm
Hey Mauser - The kickstart fell off the XR650L I am riding at the moment - Do you know where I can get one? StirPot StirPot
Chris_w_65
Post  Mauser on Mon Aug 19, 2013 5:36 pm
Chris_w_65 wrote:Hey Mauser - The kickstart fell off the XR650L I am riding at the moment - Do you know where I can get one? StirPot StirPot
Can someone send me a link to the part number for this cover in question as my online source doesn't show it.....?
Post  Chris_w_65 on Mon Aug 19, 2013 6:07 pm
Here you go - part 1 and part 4
28 is the supposed scavenge oil level check plug
Number 20 is a special bolt I am changing - It has something to do with kickstart I think - mine is a little worn - Anyone know its purpose?
http://www.hondaparts-direct.com/fiche_section_detail.asp?section=2691614&category=Motorcycles&make=Honda&year=2003&fveh=134983
Chris_w_65
Post  grizzly on Mon Aug 19, 2013 6:54 pm
It would be realy interesting, if anyone with a XR650R can turn this ominous screw out (maybe one with 17inch wheels in front).
When I do this, there is no drop of oil coming out - whether when it runs nor when its cold - still afraid, contacted Clymer now conc. this problem - wait for answer now.
Can anyone turn out this bolt and give me notice, isn't much work. If necessary, I can make a picture, where this bolt is located.
grizzly
XR650R Year : not yet
Post  BuRP on Mon Aug 19, 2013 7:04 pm
I think Bolt20 is either the hookup for the kicker's spring or the stopper for the toothed cam?
Grizzly, being Austrian is no excuse for being stubborn and not wanting to learn. I'll tell you for the last time, this bolt does nothing - but maybe you didn't read Hew's post?
Over & Out on this subject for me.
