Help identifying this exhaust
Post  SkidMark on Wed Mar 13, 2013 7:33 pm
Any info on this exhaust appreciated...
Cheers
Re: Help identifying this exhaust
Post  BuRP on Thu Mar 14, 2013 8:17 am
2 silencers > more weight, so it's no racing pipe.
Looks like a home brew Mark, seen a similar thing on a motard.
Post  SkidMark on Thu Mar 14, 2013 8:49 am
hmmm - reason I'm interested in it is that as you say two pipes mean more weight but they are skinnier pipes not probably not too much more. I would like to do either an under seat exhaust or tuck a pipe each side up and under the seat a bit to make the rear as narrow as possible.
Cheers
Last edited by SkidMark on Thu Mar 14, 2013 8:50 am; edited 1 time in total (Reason for editing : missing word)
Post  BuRP on Thu Mar 14, 2013 1:04 pm
Unless you'll discard the existing airbox you'll have a hard time to fit a pipe in on the lhs. And, those airfilter-cones are not too good for offroad, just want to mention that here Wink
Post  SkidMark on Thu Mar 14, 2013 1:11 pm
BuRP wrote:Unless you'll discard the existing airbox you'll have a hard time to fit a pipe in on the lhs. And, those airfilter-cones are not too good for offroad, just want to mention that here Wink
good point thanks. definitely not going for a cone filter!!! this is initial brainstorming - I will be making a new steel subframe to take the weight of luggage so while I am at it I have the opportunity to 'restyle' it to see if I can get the exhaust/s under the seat but I don't want to limit rear suspension travel. Did some measuring last night and the way I measure it (307mm rear travel if I remember rightly) already puts the wheel hitting the underneath of the fender scratch
hmmmm
underside exhaust
Post  temporary kiwi on Fri Aug 16, 2013 1:47 pm
ive previously made the headers go around either side of the cyl, then join up under the carb, but if your really keen, you could make the muffler body as an intergral part of the subframe, i.e a brace or monoque style of frame that has the muffer incorporated , otherwise just run a pipe/muffler either side
Post  Chris_w_65 on Fri Aug 16, 2013 9:03 pm
I am thinking of sticking a Yamaha R1 tailpipe out under my seat on my motard Very Happy
Chris_w_65
Post  SkidMark on Mon Aug 19, 2013 9:24 am
temporary kiwi wrote:ive previously made the headers go around either side of the cyl, then join up under the carb, but if your really keen, you could make the muffler body as an intergral part of the subframe, i.e a brace or monoque style of frame that has the muffer incorporated , otherwise just run a pipe/muffler either side
Yeah I was thinking along those lines of having the silencer incorporated into the subframe. Correction to what I said earlier max travel of the rear wheel gives a few inches clearance.
Next thing to find out is which oval silencer is 'flatist'.....
Mark
Post  Chris_w_65 on Mon Aug 19, 2013 9:39 am
Mark
I will never use 11" of travel on my motard - R1 pipe (just one of the set) is the right sort of length and shape - If I use a stock one I will gut it a bit - it is an awesome titanium tailpipe that comes on the R1 but they are expensive but most guys don't want theirs as they fit aftermarket
Chris_w_65
Post  Chris_w_65 on Mon Aug 19, 2013 9:49 am
I saw a pic on the net of a very flat oval one on an XR - looked awesome but I can't find the pic again :-(
What worries me is that from the back the right side plastic will look odd bulging out with no pipe under it
Chris_w_65
