crankshaft
crankshaft
Has anyone pressed the crank apart.is the balancer gear keyed or just on a taper &how is it timed.Any help would be great.
Rich
Rich
Rich- noob
Crankshaft
Pressed the gear off and the rod off with no problem at all.Thanks for all the help, I guess you all take that work to a shop.
Rich- noob
Re: crankshaft
Sorry.
Never have...
Never have...
Re: crankshaft
Hey Rich, why are you taking apart the shaft? did you have a break down on her? We should get together and have a beer let me know if you need any extra hands during the rebuilt, I would be glad to help! I am near Wonderland. shoot me an email if you want help.
IBM
IBM
bikerman- XRR Jockey
Re: crankshaft
If you dont mind could you clue me into whats need to separate the cases & replace a crank, mines locked at the rod & crank.
Appalachian- noob
XR650R Year: 01
Re: crankshaft
Rich wrote:Pressed the gear off and the rod off with no problem at all.Thanks for all the help, I guess you all take that work to a shop.
Don't take the hump with the lack of replies....maybe no one had the answers you were looking for
Crankshaft
Sorry about that ,not checked site for awhile.You will need a puller for the flywheel(made mine on lathe),bearing press and bearing pullers.We used a 50ton press to split the crank(only took 30ton).The rest is normal shop tools.The thrust washers were chewed so there was brass shavings all thu the bearings,replaced all bearing.Washed cases 3times to remove all brass.
Good luck
Rich
Good luck
Rich
Rich- noob
Similar topics» Nitriding Crankshaft
» new 4.6 forged crankshaft SOLD
» Crankshaft/engine-sieze problems?
» CHEVY V-8 Crankshaft Journal Sizes
» WTB Boss 429 Crankshaft
