Rod bearings
Rod bearings
Post  Rich on Thu Sep 08, 2011 7:52 am
Rod bearing on my 2001 seized ,tore down motor and found brass shavings everywhere.Thrust rod washer was chewed and seized the rod.Any idea on what caused the problem.Was in 2 gear & not really on it when it seized.
Rich
Rich
Re: Rod bearings
Post  BuRP on Thu Sep 08, 2011 12:26 pm
"Any idea on what caused the problem?"
Age, plus that the early years apparently had different/not so good thrust washers.
Depending on how "on it" you ride you may consider a Falicon rod for your rebuild.
Re: Rod bearings
Post  AURORA on Thu Sep 08, 2011 5:22 pm
Did the previous owner and or you lug the motor at low RPMs? Just curious?
Blown Rod Bearing
Post  Rich on Fri Sep 09, 2011 7:49 am
Not sure if other owners luged it.Only owned for few months.How do I tell if there is a high compression piston in it?or cams? And where do I get a Falicon rod and piston and bearings ?
Rich
Rich
Re: Rod bearings
Post  BuRP on Fri Sep 09, 2011 8:33 am
Falicon does (as far as I know) rods only.
You'll find all at xrsonly.com, they even could do the work required - which, if you're in the US may not be a bad idea.
Any non-std parts you find by measuring, however I'll admit that's easier then you've got the std parts also. Plain good looking should tell you quite a bit though - but, that assumes you know what to look for.
