Rox Risers
Rox Risers
Post  Jimmyx on Tue Aug 30, 2011 5:57 pm
I just ordered a set of 2" Rox Risers, Can I use stock cables?- Anyone else running this set up?
Jimmy
Jimmyx
Re: Rox Risers
Post  dirtyoffroad on Tue Oct 04, 2011 6:33 am
I cant answer just yet,but I plan on the same thing,only thing holding me back is I dont have the factory 7/8 bar clamps to clamp the riser into the triple clamp.
dirtyoffroad
Rox Risers
Post  Jimmyx on Tue Oct 04, 2011 7:04 am
I installed these last month, Rox risers are milled for 1 1/8" bars,7/8" at the triple clamp and they supply shims for 7/8" bars. If you are running 1 1/8" bars you can Probably use the shims for the 1 1/8" mounts at the triple. You will not need longer cables, just a bit of rerouting on the clutch and decomp levers. you will also need to rotate the throttle cables down a bit. Here are a few shots of my set up. (see first photo OF shim on my 7/8' BARS)
Best,
Jim
Jimmyx
Longer Cables
Post  JimmyO23 on Mon Nov 14, 2011 2:45 pm
I am 6'5" and I bought a new riser and bars and I still feel like I can't stand up and feel comfortable. I rerouted the cables so I can't go any higher without buying new ones. Does anyone know where to buy longer decompressor, clutch and throttle cables???
JimmyO23
Cables
Post  Jimmyx on Mon Nov 14, 2011 4:55 pm
looks like Motion Pro has them all....Link
http://www.motionpro.com/custom/index.php Smile
Good luck man,
Jimmy
Jimmyx
Re: Rox Risers
Post  JimmyO23 on Tue Nov 15, 2011 4:35 am
Thanks Jimmy banana
JimmyO23
