Sounds like clutch basket?
Post  k30 ccm on Fri Aug 26, 2011 11:28 am
Hi everyone new to the forum, but would be great if someone could give me advice on what sounds like a noisey clutch? All gears and the clutch itself works well but there is a definate noise from behind the clutch cover. not pulled it off yet, thought i might take some advise first. Do clutch pressure plate bearings give problems/noise sounds a bit like a rum Question Question mble but dont think its coming from bottom end, it's behind clutch cover? Thanks Question
k30 ccm
Re: Sounds like clutch basket?
Post  AURORA on Sat Oct 08, 2011 6:30 am
Are you running a plastic factory skid plate or an aluminum skid plate?
Post  Mauser on Sat Oct 08, 2011 8:01 am
What year is your bike ?, does it make the noise when clutch is in or out or both ?.
www.xr650r.co.uk
Post  BuRP on Sat Oct 08, 2011 11:51 am
Pull the clutch!
Your year's model (2002) may have the faulty bushing which was replaced that year. The replacement-bush has some indentations ground (or cast) in it for better lubrication, which the wrong one lacks.
This bush will wreak costly havoc if is seizes, and they will do that.
If your clutch still works then fine, but pull it soon, and put the improved bush in if it needs it. Besides, you can then visually go over all to see if there's more.
