vapor computer tach wire
wut up guys.installin a trail tech and wondering where best place to install tach wire.to the coil or wrap around the plug wire?if coil,wut wire to tap in to?any info is greatly appreciated.thanx
amador97- noob
Re: vapor computer tach wire
Wrap around the plug' wire, in the middle between coil & plug-cap.
According to Vapor you may T-off into the system, but you're on your own here!
If something goes wrong your bike may not run, and this cannot happen if you simply wrap it around - hence electrically insulated, it just picks up a little induction (kinda magnetic).
"Tune" the Vapor by deminishing/adding wraps as per the manual, it'll work.
Burp,thank you very much!Gonna go that route.Didnt know which was better or more accurate.
amador97- noob
Tach wire
I did mine the same way but had about 12 wraps around the coil wire. When I fired up my pig it was off the charts....So I took off 7 wraps and did 5 like the manual said. Same thing....off the charts, I eventually realized I had the tach wire switched with the temp gauge ? It was the only other one that I could have switched, anyway it works fine now. I tried using the method the manual suggests for calibrating the speedo. Never even came close. I took about 20 rides down the edge of a tomatoe field with my GPS and adjusted the numbers until it was exact, now it is really an accurate tool, it seems the default numbers for wheel diameter are off a bit in the manual, at least for me.
xabntroop- noob
Similar topics» LEDS turn signal wiring (two wire leds work as a three wire)
» Vapor installed on an X help
» Standard Instruments to Tach 1970 Mach 1
» DGCA computer number!
» CS501 Quiz (Advance Computer Architecture) Quiz#1
