noisy valves?
noisy valves?
So i bought a 2003 honda xr650r a week ago, needs lots of TLC. Valves needed adjustments , the intake valves were pretty off...
the previous owner told me there is a hotcam in the bike . And im wondering if its the hotcam is creating that noise , is it normal ? Bike is straight pipe.
Heres a video posted on youtube : http://www.youtube.com/watch?v=9J4CEQbHVEg (this video is before valve adjustment)
part 2 ---> http://www.youtube.com/watch?v=IIcRn2W0xoQ (after valve ajustments , still doing the noise ) ...
Did some research online, some are saying , rocker arms , some are saying timing chain and tensioner .
anyways i wanna see what you guys have to say about it . Before i have no choice but opening her up .
jeronimo- noob
Re: noisy valves?
You sure you have her in the right position before adjusting the valves ? you can be on the "T" mark but not the right position for the engine @ TDC
Re: noisy valves?
Sorry Mauser,
but being 1 revolution out - but on the T - means that both valves are lifted quite a bit, they're then "rocking" in/during their overlap..... and I don't think that's what's amiss here. That aside, you'll have to turn the tappets a ludicrous amount to even get play then, if that's possible at all!
Jeronimo,
You must take the LH-cover off, and you must turn the crank only counter-clockwise... which means not/never/ever turn it even a little clockwise!
Turn at least 2 full turns counter-clockwise, to the T, and if the valves don't have free play then turn another revolution, again counterclockwise.
If you go past the T then carry on turning, but NEVER turn the crank clockwise!
This thing has an auto-decomp system in, which reacts on turning clockwise, it will lift a valve then.
Mind though, some 'hot' cams do away with this decomp-system, and you'd better check if you still got it (by turning it clockwise & see if the exhaust valve lifts then).
Jeronimo,
Re: noisy valves?
sounds like lots of people are making this common mistake?
the only thing i did was removing that little screw on the LH cover so i could see the Marks to align . with the kick start, and slowly turn it to the mark , But there was 2 mark (one beside each other) , i took the first mark . Check the valves and there was freeplay , so i assumed that i was at TDC . and then ,i adjusted my valves... could this be my mistake .
jeronimo- noob
Re: noisy valves?
Jeronimo,
best is to do as I described above - which, btw, is as per the Service Manual..... which you've got I assume? If not google it, download it, print it & rear it. After all that you may file it.
I actually forgot to say that you'd better take the sparkplug out too then, to make things easier as well as safer.
However, if you didn't know you probably - I'm careful here now
don't know a couple of other things typical for this bike? Read my man, browse until you know all. Checking the oil for instance, you know how that works do you? For sure I mean?
I trust you do but will tell it here nonetheless, as others read here too:
Start the bike, let it run a bit, then ride it until warm, say around the block. Park it level (on a bike-jack for instance), take out the dipstick, wipe it clean, then push it back in on the thread, take it out & see what the level is.
That means do not screw it back in for measuring, and do not measure unless having run the bike first (you'll measure 'low' and probably will overfill). Plenty people overfill, and consequently blow seals & create a leaking bike.
This is a so-called dry-sump engine which has dual oilpumps, and carries the oil in the frame..... when it is running or just has been run. When off the oil will leak past the pump into the sump, therefore creating a 'low' level in the frame - which is normal, you just need to know this.
Re: noisy valves?
i know where your going with this... Just so happens that the manuel arrived by mail today!
But yeah i did try to save some time and take shortcuts . not always the solution .
i will refer to the manuel next time .
Ill keep you guys updated , when ever i get a chance to redo the job . And dont worry im not going to drive the bike with noisy valves lol
jeronimo- noob
Re: noisy valves?
Hope this help dude.
http://www.xr650r.us/tech/valves.pdf
lolo- noob
Re: noisy valves?
Got a chance to work a bit on the bike this week end . Turns out its the rocker arms that are worn out !
Heres some pics : http://i1198.photobucket.com/albums/aa452/jeronimo12/IMG_0466.jpg
http://i1198.photobucket.com/albums/aa452/jeronimo12/IMG_0467.jpg ( as you can see the top of the valves on the left are smashed , wondering if there still good , or should i just change them , just to be safe . )
http://i1198.photobucket.com/albums/aa452/jeronimo12/IMG_0469.jpg
jeronimo- noob
Similar topics» Noisy Neighbours
» noisy valves?
» cleaning mk4 sticky noisy starter
» noisy tappets...
» remove radiators to adjust valves?
» noisy valves?
» noisy tappets...
