Added indicators
Added indicators
Post  Mauser on Thu Feb 24, 2011 1:21 am
Hi guys,
Swapped out my loom and stator for a European version and have added indicators, thought I would share my brackets with you guys showing how to attach them without needing the rear subframe. They work very well and I can still move the bike about without catching them.....
Re: Added indicators
Post  rikco on Thu Feb 24, 2011 3:46 pm
nice
i still got the extra subframe underneath the fender makes it much stronger and my blinkers are attached to the license plate holder with the rear/brake light.
if someone is searchin for the original xrr blinkers? i got them brand new in unopened package just let me know naughty
Post  BuRP on Thu Feb 24, 2011 11:36 pm
Ricko,
do's a favour and post a photo of that subframe please? I'm busy mounting a small rack and want to reinforce this a bit, have parts made already, but would like to peruse how Honda did it - that is, assuming it's a genuine Honda part.
But also if it is not, let's a have a look please?
Zou fijn zijn Wink
Post  Mauser on Fri Feb 25, 2011 4:00 am
BuRP wrote:Ricko,
Zou fijn zijn Wink
Burp, bit of info for you the European 650's have additional mounting lugs on the subframe for attaching the steel rear frame to, mine doesn't have these as it's a US version.
Post  BuRP on Fri Feb 25, 2011 10:35 am
Mine neither Maus, it's a Cal-bike. But that's why I'd like to see pic, maybe I can weld same to my subframe.
Hope he will post a pic........
subframe
Post  lolo on Tue Mar 15, 2011 11:54 pm
hey burp,
Is this the sub frame pic you looking for.
This is the light indicator that comes with the frame
lolo
Post  Mauser on Wed Mar 16, 2011 2:12 am
There is also some extra mouting points for the rear bracket thingy under the seat further back, the photo's doesn't show these.
Post  BuRP on Wed Mar 16, 2011 5:10 am
Yes Lolo,
Thanks, that helps, but my idea was/is to support the part in the photo from the lugs on the frame lower down (the one's Mauser mentions) by means of some braces.
If you've got a pic of the lower lugs..... I'd appreciate!
Post  rikco on Sun Mar 20, 2011 7:29 pm
yeah i mean the same as the pictures above
its also attached to the frame but on the pictures you cant see it.
its original honda for the european model.
Post  bikerman on Fri May 13, 2011 8:00 pm
Rikco do you still have the blinkers? can you send me a pic?
IBM
rikco wrote:nice
bikerman
Post  rikco on Sat May 14, 2011 2:48 am
yeah still got them
Very Happy
Post  bikerman on Sat May 14, 2011 9:39 am
How much do you want for them? Are they square? looks a little big, don't they? I am try to install smallest I can but anyways PM for the price please. Thanks,
IBM
rikco wrote:yeah still got them
Very Happy
bikerman
Post  rikco on Tue May 17, 2011 5:08 am
i think the shipping cost to canada will be to much, im from the netherlands you know? cheers
Post  bikerman on Tue May 17, 2011 4:32 pm
Ok Rikco, thanks anyway.
IBM
rikco wrote:i think the shipping cost to canada will be to much, im from the netherlands you know? cheers
bikerman
Post  bikerman on Tue May 17, 2011 4:35 pm
Mauser,
Do you have any kit conversion for the signals? can you give more info how you did install them? do you have also mirror, hi beam, stop lights and horn? Please I did to do my conversion before July since I booked my driving road test since I let my california driver license expired now I have to start all over again in Canada. Dawn!.
Thanks for the tips and which his the best way to do it.
IBM
Mauser wrote:There is also some extra mouting points for the rear bracket thingy under the seat further back, the photo's doesn't show these.
bikerman
Post  Mauser on Wed May 18, 2011 12:24 am
Hi Bikerman,
Conversion kits ?, not sure what you mean, what I have done to get my bike how I like it....
Swapped loom with friend www.xr650r.co.uk which is a stock UK spec loom along with the stator, then added pressure switches to the brake lines to operate the rear brake light, this is the difficult part as I like the single stock fender light, I removed the stock single element bulb holder and converted a twin LED bulb into my stop and tail light. Added a horn and new switch gear and swapped out the headlight assembly.
Indicators I made the rear brackets as pictures as my fender won't take the steel subframe + didn't want steel parts on the bike lol, they all go rusty, extended the wires on the indicators and plugged them into the stock wiring loom, all the electrics works fine I have high and low beam and should pass the MOT easily in July.
Give me a shout if you need any specific pictures or info.
Post  bikerman on Wed May 18, 2011 1:25 pm
Ok Mauser, Lets start with what I have right now, I have the 2 hydraulics brake switches, what else do I need to install them? do I need the Banjo Switch?
I order my stator from Ricky stator and the regulator this morning, now i am ordering the Vapor with the key, I don't think it is necessary with the Key since it is 100 bucks diference just because of the key, the one without it is 97 US. so I am thinking about it. I need the signals, horn and a mirror any web site in Canada to order them from? I should be good to go and do my mods.
Please at least tell me the things I need to buy so I can start my little project on the weekend!
Ivan
bikerman
