rear brake pedal
rear brake pedal
does anyone make a rear brake pedal extentsion for the foot of the brake pedal, mine is a bit bent, and I struggle to find it with my big foot...
mortaygo- noob
geezzus
for passionate XR650R owners, you lot don't have a great deal of input.... or do you need to be a part of a special purple circle to get a response....
mortaygo- noob
Re: rear brake pedal
do remember ballards having both footpeg and brake pedal extensions a while ago,maybe worth a try.Also i get about 300-350 km out of the acerbis tank on the xr,with general open dirt roads,not a great fan of the acerbis tanks shape (bit hard to move up forward when cornering),the aqualine safari tanks seem better.
giantpiggy- noob
XR650R Year: 00 00 ktm660 rallye
thanks mate
didn't realize we spoke a different language here in Oz.... dam seppo's must not understand our accent even when we type
mortaygo- noob
non native speaker
so please try your best British incest Englich for me
stock rear brake pedal is steel
why dont you just bend to where you like
if it is to short simply extend by welding in some flat iron
while you are at it,
weld a big washer to the back no, to the left side,
hmm the side of the tip facing the engine cover,
to provide a bigger surface and less risk of bashing in the engine cover with your own lever
same with your shifter
you also can adjust the height of your rear brake lever
by adjusting the stop bold
fiep- noob
XR650R Year: 2000 & 2005
Why not just put a case protector instead of welding a washer to the back side...LOL
NOT TO BUST YOUR BALL BEARINGS HERE BUT...
Hey man,
I posted the solution to this a LONG time ago on here so before picking on anyone you might do a thorough search. I know the search doesn't work very well but still it's here and I usually post new stuff I run across. Plus, I check the new posts section all the time but don't remember seeing yours or I'd have replied. Don't hesitate to email me directly if you have a ?
Here it is again: http://www.hdmoto.com/
Also know that the Team bikes usually file down the teeth on the case side so a bend doesn't dig into the cover.
RIDE RED
RIDE RED
mortaygo wrote:for passionate XR650R owners, you lot don't have a great deal of input.... or do you need to be a part of a special purple circle to get a response....
That's funny!
I will give you some props on the special purple circle comment. Excellent social criticism. They're about as sincere as all the FUs on AdvPoser.
Similar topics» REAR DISK BRAKE SET RM450
» EVO UPGRADED BRAKE KIT REAR - USE WITH 17x8J ET25 TOMBINOS
» EVO UPGRADED BRAKE KIT FRONT - USE WITH 17x8J ET25 TOMBINOS
» New Billet LS430 Big Brake Adapters for Late offset (87-up NA)
» Ream for rear swing arm
