Need input on the condition of my engine
Post  kashmir on Fri May 21, 2010 5:04 pm
My friends dad deals with engines and says mines about to go. I took a video of the idle to share here for more input. Please help!
kashmir
Re: Need input on the condition of my engine
Post  AURORA on Fri May 21, 2010 10:50 pm
Have you checked the valve lash for proper clearance/adjustment? Sound like the valves might not be at their proper adjustment.
Post  kashmir on Sat May 22, 2010 12:23 pm
Just adjusted them, I might be a little off, since it is my first time. Wanted to know what other reasons it might be. But the problem does seem to be in the head and not in the piston right?
kashmir
Post  AURORA on Sat May 22, 2010 7:52 pm
Did you check the adjustment on the compression release?
Have you done any work to it lately?
Post  Bump on Sun May 23, 2010 9:34 am
Have you been inside anything? I'd pull off the side covers just because it's an easy check. It sounds a little high pitched to be down low in the engine.
Post  kashmir on Sun May 23, 2010 6:50 pm
I redid the valves and sounds much quieter. Ill post a second video
kashmir
Post  AURORA on Thu Jun 03, 2010 7:21 am
Yo Agent K,
An improvement on the operation your engine? working on it
