Need help with poorly running XR650R
Help! I have purchased a 2001 XR650R and am having the following
issue:
Starts easy by 2nd kick, runs great and
jetting is spot on. Runs great until temp (read on my Vapor computer)
hits about 220 F after 20 minutes and then just completely boggs and
will not rev over 3,000 rpm until the bikke cools off.
Unplugged
but basically stock.
Any ideas?
issue:
Unplugged
Any ideas?
alivingston- noob
Re: Need help with poorly running XR650R
above 220F?
why does your tem rise that high?
according to my Vapor even in upper 80s
temp while riding stays below 190
sitting in traffic it once rose to 210
fiep- noob
XR650R Year: 2000 & 2005
Sounds like your thermostat is stuck.
joenuclear- noob
XR650R Year: 2000 & 2001
yeah the stat was stuck ... took it out and she runs around 175 ... but as suspected the cut out at around 5,500 rpms kicks in ... suspect the coil so just ordered a new coil and HT lead/sparkplug cap. will post my findings when the parts arrive.
Any other thoughts as to the issue?
Also I have a Baja Designs kit installed but that should not be an issue ... right?
alivingston- noob
to me...
Don't know much from the description but it sounds to me like fuel. I've seen a few guys who had the gas boil a little near the petcock so they put reflective heat tape there. But the fuel could be boiling in a few places.
Similar topics» my mk2 is running lumpy
» Gaining Mass.... While doing lots of running = possible?
» Combining bodyweight exercise and distance running
» Need help with poorly running XR650R
» 2000 xr650r love this pig with monster meat teraflex tire
